adam.culyer Posted March 31 Posted March 31 ok so the problem is intermitantly the drivers controls for the windows wont work and when it starts to work again it only operates the drivers window but only if you drive the car for about 10 mins. i have had a few zafiras so straight to check the wiring and clean the switch no issues withg the wiring even through the rubber gaiter at the door and the switch is lovely and clean i even tried another switch but still no change. i have had a look at the BCU behind the glovebox under the aircon unit but cant see any obvious water damage. does anyone have any suggestions Quote
