paulbw67 Posted January 2, 2013 Posted January 2, 2013 The front 12v Power socket on my 2005 (05) Vectra SRI has stopped working. I have checked the fuse (location 22); it was ok, but I replaced with a new one anyway (30A green). Anyone have any ideas what may be the problem?Manual states that Fuse 22 is the "cigarette lighter" - if the cigarette lighter isn't fitted, is the power socket supplied by a different fuse?I haven't removed the socket yet to check a wire hasn't come adift (is that an easy job?)I'm sure it isn't related, but on the day it stopped working I replaced the headlamp & parking light bulbs and cleaned the windscreen washer bottle filter.:-(ThanksPaul Quote
Steve Posted January 3, 2013 Posted January 3, 2013 Hi PaulWelcome to the clubI would say that it's more likely to be the Unit itself and probably a loose wire from the back or the actual connectioninside has snapped? Do you use it a lot? Quote
paulbw67 Posted January 3, 2013 Author Posted January 3, 2013 Thanks SteveYes, use it a lot for an iPod and/or mobile phone charging. Can use the rear socket, but it's a bit inconvenient so guess i will have to try and remove the unit and check it out (which doesn't sound like a simple job) Quote
